My gas cooker oven wont heat up. I suspected that the thermostat was broken and replaced it. The burner lights instantly but it will not turn up has anyone any thoughts as to what the problem may be
As Mr D said. You've wasted money on a thermostat when that was not the fault.I know what the fault is and so would your RGI, and he would also be able to check your work.
