cannot lock door
24 Apr 2007
Cheshire
The key in my conservatory door snapped off whilst in the lock, I cannot lock the door now. How can i get the bit of key out that is in the lock????? Help????
Ann
Is it something like this one?
images
Do you have a spare key? If so, use a screwdriver or flat object to move the side of the cylinder with the broken key to the vertical position - ie the jagged edge of the key would be pointing downwards. Then use the spare key in the other side of the cylinder to push the broken section out. You'll probably need a pair of pliers to pull the broken key out - once you can see it.
