I got an issue where my front door does not lock with the key from outside but using the thumbscrew inside you can lock and unlock the door.
So I thought easy fix I will change the cylinder but when I change the cylinder you can lock the door but cannot remove the key?
The old one works fine locking and unlocking from inside using the thumbscrew.
Is a thumbscrew cylinder different from a normal cylinder or is my mechanism in the door that is also faulty as well as the original cylinder?
Thanks.
Thanks.
