I am unable to undo some internal door handles. The handles and doorplates each side are held together by two bolts (4mm dia. X 40mm long, with screwdriver slot heads) which locate in tubular "nuts" (15mm long) also with screwdriver slot heads.
When the handles were fitted, the bolts kept undoing, so threadlock was used to hold them securely. Now that I do need to remove the handles, unscrewing the bolts is proving impossible as the screw heads are getting chewed up.
Any suggestions for undoing the bolts (ideally non-destructive)? Also, does anyone know where I can get replacement bolts and nuts - I don't want to have to replace all 11 matching door handle sets in the house.
