I want to replace my immersion heater and need to drain water from the top of the hot cylinder before I unscrew it. I attached a hose to the drain cock at the bottom, turned the nut and.....nothing. The drain tap is obviously furred up inside (the cylinder is very old). The sparky who came to fit the new immersion heater was there when I tried this (I'd agreed to get the tank drained myself before he came) and he said that he'd seen plumbers disconnect the pipes at the top of the cylinder to drain some water off that way. He also said that he'd seen a new drain cock fitted beside the old one while the tank was still full - is this possible? Anyway, any advice appreciated. (The spark didn't charge me, by the way, but will come back when I've managed to drain some water off by any means available.
