Hi
We recently moved into an old property with 12V halogen downlights fitted in the kitchen ceiling. I purchased larger diameter replacement LED lights and went ahead and removed one of the halogens and cut a larger hole to accept the LED. I put my hand in the the larger hole to remove the transformer and……………..no transformer! I removed the other halogen lights and none of them have a local transformer! I’ve used a mirror on a stick to search around in the ceiling void but no transformer in sight!
The kitchen is quite large and above it are two bedrooms and part of the landing all of which have fitted carpets, grippers, underlay all laid on top of hardboard nailed down on top of the floor boards. I really don’t want to have remove this lot and pull up the floor boards on a wild goose chase looking for the transformer(s) which may not be located there at all.
Incidentally the LEDs require an electronic driver and will not operate on the existing 12Vac.
I’m at a loss what to do. I contacted the previous owner who told me the downlights were fitted by an electrician many years ago. I can’t believe an electrician would be stupid enough to locate the transformer in an inaccessible place, if the transformer goes faulty we would lose the lighting to our kitchen!
I’m just wondering if anyone has any suggestions. Would a cable detector be able to sense into the ceiling void and discriminate between a cable and a transformer? I’m clutching straws now
