I have an open vented ch system that I need to drain down because of hot water issues. I can't seem to find the drain cock which I know is usually on the lowest point of the pipework.
My question is (as I've only done this once in a different property so forgive my ignorance) can I use a radiator valve to hook up the hose/jubilee clip to?
There is space right next to my back door for a radiator - there isn't a radiator there it's just the in/out pipes that go either end. Can I just attach the hose here to drain down the system?
If that's not possible, where else can I attach the hose?
Appreciate your help!
Gavin
Gavin
