Hi I had 2 x 100watt bulbs in loft that worked fine. Coming into the loft the first light goes into a pendant fitting and I wired a cable off to another as in parallel. I replaced the 2nd bulb with a fluorescent and it worked with the 100w still in place, then when I added the 2nd the 2nd one just flickers. I replaced the bulb and the little diffuser thingys and they both work ok in garage light so its either the light unit or my wiring!
I can doubel check by changing the garage unit that works and put this in the loft but if it does not work what could be wrong the buld at the end of the line i.e the 2nd one always works and the 1st bulb just flickers. In the pendant join I have 3 earths in the earth screw, 3 lives in the live and 3 nuetrals in the neutral, the bit that says loop with 3 screw terminals is unused. So really its cable in and back out to 2nd light I have just teed off to my othe flourescent or should I just go into the 1st flourescent and then back out to 2nd light! Also the wire in is just from a switch.
Any advice would help, I will swap light tomorrow as this evening was spent problem solving already!
regards
regards
