cant get rid of pop ups...help!!!
23 Dec 2006
Kent
hi, im running windows xp sp2 each time i launch explorer i get a pop up (casinos or dating) then again about every 5 mins, i have run spybot, windows defender clean disk cookies and set the pop up blocker to highest setting but still no luck,
how do i get rid of this? or is it a restore job?
many thanks
Have you run adaware?
You may need to disable System Restore, run all your cleaning progs, restart, run them again, if clean, turn System Restore back on.
Hi unclebuck001
If nothing here works for you do this.
Download Ewido/AVG Anti Spyware from here ….
http://www.ewido.net/en/
It has a fully working 30 day trial period.
Install it and update it to the latest definitions.
Do NOT use it yet.
Now boot to safe mode. Here’s a “how to” if you’re not sure ..
http://service1.symantec.com/SUPPORT/tsgeninfo.nsf/docid/2001052409420406
When in safe mode run a full system scan with AVGAS and let it fix what it wants to.
REMEMBER TO SAVE THE SCAN REPORT and also remember where you saved it.
[FOOTNOTE > this is a good program to use as an “on demand” scanner even after the trial period is over. Keep it updated and use it to scan your computer from time to time].
If all your work doesn't succeed in fixing the problem download HijackThis from here ...
http://www.majorgeeks.com/download3155.html
unzip & install it ...
open the program ...
from the menu click on "Do a system scan and save a logfile".
Copy and paste that logfile to this thread. More specific removal instructions will follow for whatever it is that's causing the problem.
PCH
you must check for not going onto pornographic sites you have got it from there.
