my kitchen supplier has just informed me i cant have an induction hob as they require a large clearance (i guess for heat?).
The hob installation states that this type of installation requires a minimum thickness of worktop and a minimum gap between the bottom of the hob and the top of the oven.
They have given me the option of:
1) change to a ceramic hob
2) loose 2 draws
3) change the 30mm granite to 40mm (two 20mm pieces stuck together)
2) loose 2 draws
