This is a bit of a saga!
I am changing a cistern - I had a problem getting the plastic pipe off the inlet pipe so I had to saw it off. There was a micro valve that I used to isolate it at this stage and then unscrewed the top part of it. The plastic pipe was jammed solid and I couldn't remove it. So I ordered a new valve but it is a slightly different thread on the top part so I need to change the whole valve (rather than just screw the new bit in which would have been simple!)
So I turned off the main supply under the downstairs sink which isolated some of the cold taps and another toilet but not this one. I assumed then that it must be fed off the tank (we have an indirect system). I went into the attic and found a valve on the outlet pipe leading to this bathroom - turned it off but it didn't isolate the toilet!
So is this valve broken or am I missing something else. Could there be another stop-cock that turns off the supply to this bathroom, or do I need to drain the tank (I'd rather not)?
Help?
Cheers
Ian
Help?
Cheers
Ian
