I have a Bosch Clasixx 2466 Washine Machine and something is stuck in the Pump Filter which is preventing me from removing it.
I can turn it only about 1/4 turn and then it is stuck.
Any ideas ?
JJ
You'll either have to force it and possibly break it or strip the pump and filter assembly out of the machine and see if you can shift the blockage from the hose ports.
Thanks for the replies.
The washing machine is still working perfectly well so I am reluctant to force the cap off at this stage.
Do you know if it is possible to remove the whole filter assembly from the front of the machine ?
Thank you
Hurray !!
I finally managed to remove the Pump Filter Cap by unscrewing it, It was a small twig which was preventing it from being released.
Thanks for all the replies
JJ
