Can't Remove Cartridge From Tap
27 Sep 2011
Both hot and cold taps were constantly dripping...
So i decided to replace both ceramic tap cartridges.
As expected the hexagonal nut was stiff but using a adjustable wrench i managed to slacken the nut to remove the cold water cartridge.
However the hot water tap on the left is wont budge. I have tried WD-40 and heat. Still no luck.
I tried so hard to remove it that I have almost rounded off the nut.
What advice would you guys give? I really don't want to call out a professional to charge me for 5 mins work.
The annoying thing about all of this is that the tap is under warrenty but I have lost my receipt.
I have decided to invest in a Cordless impact driver and socket set.
Mainly because I can see myself struggling with a ratchet and think that some electrical power may be the best option to remove this stiff nut.
Can anyone recommend a decent/reasonably priced impact driver/socket set?
