Okay I have a strange problem...if anyone can help that would be great!!
I have a Potterton6002 timer controller and a Potterton Profile boiler.
Here's how to produce the problem:
1) Put the HW on (either via timer or on constant)
2) Put the CH onto constant
3) Put CH to off
But, the CH stays on. The light on the thermostat stays on, and if i turn the thermostat right down, it stays on. The only way to turn the CH off is to turn the HW off. However, if I then turn the HW back on, the CH also comes back on even though it is in the off position!
The only way to the CH off is to...
1) Put the CH into the once position, ensuring that the CH does actually come on (i.e. the light on the controller and thermostat comes on)
2) Turn the thermostat right down, so the light on the thermostat goes off
3) Turn off the CH on the timer
I had no problems with the system until a few months ago. I thought there might be a problem with my timer so I replaces an ep2002 with an ep6002 but it has not made any difference.
I did replace the thermostat earlier in the year...
Any ideas would be much appreciated!! Thanks.
3) Put CH to off
