I have a Vaillant 637 system boiler, which has the newer Grunfoss pump. On the top of the pump towards the back is what looks like a grey tyre valve cap with a small hole. I'm assuming this is used for venting the pump?
I noticed a bubble of water coming out of it and white (limescale?) on the pump around it, so it appears to be leaking slightly. It can be twisted and was loose. I unscrewed it a little half expecting to see some water come out of the hole (like a radiator bleed valve), but nothing happened so I screwed it back to how it was (not quite as tight as it could get).
Does this indicate an issue with the pump? Should it be as tight as it can get?
Thanks.
Thanks.
