Any recommendations for cap sheet adhesives that can be applied all weather ? I need to implement a temporary fix over some leaking felt till spring and torch is out of question.
It is already tarped but that's causing leaks elsewhere and the gusts are stressing me out. I'm going with Wayners advice and going to use some CT1/OB1.
I had a leaking felt roof and used Evercryl on it. Quoted £800 to re-felt it. I painted Evercryl over the crack, and put an extra strip of felt (which I had in stock) on top and stuck it on with more Evercryl. Cost me about £30 and it's been OK for 4 years.
