O
overlandrover
Last year we had our soild fuel boiler replaced by an electric boiler. The technician that fitted the electric boiler cut back the flue the the ceiling, filled part of the flue with insulation, and then applied cement to the underside to seal it.
Over the winter, especially after driving rain, brown water has dripped through this cement, leaving stalagtites of a gooey matrial, and a bad stain on the ceiling of the boiler cupboard.
The recent dry weather means it hasn't been too much of a problem lately, and it would be a good time to remove the existing hood top, leave the flue to air out, and then cap the chimney permanently.
A builder has recently advised us to cap the chimney with a waterproof cement, sculpted into in a pyramid shape. I would prefer to simply use a pier cap which would have a 1½" overhang all around.
I plan to remove the flue as far as possible, but I think this is going to be difficult.
My concern is that moisture and condensation always finds a way into the flue, and regardless of the capping technique we may still get rusty water dripping through next winter.
Does anybody think the proposal is a good idea?
If so, should the flue be filled to the brim with some material (such as fibreglass, or perhaps polystyrene beads as per cavity wall insulation?)
Should the void between the flue and the chimney also be filled?
I look forward to your advice.
