- Joined
- 8 Mar 2021
- Messages
- 5
- Reaction score
- 0
- Country
Afternoon all,
I have recently made a post regarding condensation in the loft, but now believe that to be a very separate question to the following, so hopefully get a more specific answer here regarding my chimney.
I recently had a 2 x chimneys capped, unfortunately I have since found out it was potentially done wrong.
They were firstly boarded off inside the house, and then paving slab cemented on top. I did ask about vents being fitted but was informed they are not needed.
After reading further is it right that vents should be fitted inside the house and at the top?
I have plans to fit a Positive Input Ventilation system in my loft to help combat internal moisture (had this in last house and rate them) but I am unsure if having active vents inside the house, would make this pointless.
Thank you.
Thank you.
