Car EPDM rubber foam repair - which glue?
8 Jul 2008
Derbyshire
I have a tear in some epdm rubber foam car insulation. It fact one bit has torn off. They are bits that wedge into parts around the bonnet.
I know this material is very difficult to glue as it is a foam type rubber, and very porous.
Very difficult to find a good answer online. Most of the results seem to indicate some specialist industrial glue.
This is as close to a demonstration for the type of rubber I can find.
From what I understand, normal superglue and contact adhesive would not be effective.
Any ideas or actual experience on something that would work?
Double sided sticky tape or some yachting type tapes that stick to various surfaces?
not sure that would
that would not really work as it is a non uniform tear. It would be like trying to sticky tape a chunk of foam.
This looks interesting:
Might just be an advertisement. But that's similar rubber, mine is just a big wodge of it.
Edit: Hmm, looks like it might just be a standard superglue
It's chemical component on the tech sheet is just Cyanoacrylate, which is the same as most superglues.
Silly question maybe.
Does it need to be glued ?
Not a silly question. I have considered putting it back in part torn.
Is it a part that is integral to the car? No. So it in that regard....it's not a major issue.
But, I'd rather try to keep it all in one piece as it is a moulded rubber foam part.
Also, it's just useful to know what can actually glue this stuff.
A bit more digging at it seems that not all Cyanoacrylate based glues are equal, there are different formulations.
It's just a case of finding something I don't have to buy in industrial quantities.
Something like this might work:
I just assumed someone would have had experience glue repairing stuff like this before.
