- Joined
- 25 Apr 2016
- Messages
- 2,713
- Reaction score
- 651
- Country
I hope someone can give me some guidance, please.
Vehicle :- Honda Civic Tourer 2017. Petrol / Auto
Problem :- the Driving (Head) lights are not bright enough to drive with especially on Dip beam - in fact I've taken to using the Fog lights to supplement the permanently On dip beam. Last night driving along the A14 the lights seamed to dull, yellow/orange without much range.
Of the A road using main beam the road illumination was a little better but still not what I say 100%.
Bulbs are H7 55w Halogen.
The headlight reflectors (Main beam) and Lens (Dip Beam) are clean and shiny and no signs of moisture inside the light assembly.
Headlight levelling system is set high but does definitely work.
Spoke with the dealers who I bought the car from and who service it. Their suggestion was check the bulbs for cleanliness and signs of clouding on the inside of the bulb envelop.
Well that 2 hours to get to Offside bulb and check it to find it is clean internally and externally. It took another 2 hours to get it and the other bits that had to come off to get it back (you really need a 5 year old to get their hands into the back of light assembly to get to the bulb!).
Checked voltages (with a 10MΩ voltmeter as follows :-
at Battery terminals engine Off 12.6v on 'Hot' side of headlight bulbs with lights on 11.5v
at Battery terminals engine On, fast idle (1500 RPM) 14.4v. on 'Hot' side of headlight bulbs with lights on 13.5v
There are relays in the power to headlights circuit.
Does that volt drop at the headlight bulb seam right?
Thoughts? Where to investigate further?
Edit:- Changed Title to bump question up the list.
