- Joined
- 11 Sep 2007
- Messages
- 827
- Reaction score
- 6
- Country
The door lock on my old 'static' caravan has just rusted through and fallen off so I need a replacement, but so far I can't find anything suitable. Must be at least 15-20 years old. There is the same type of lock, still intact, on the caravan's other door.
The current lock is from 'HM Doors' (I can't find them online) - it has a Yale-type of lock on the outside and a small circular lever on the inside.
The barrel and screws pass though a 30mm circular hole in the aluminium door - and that's it. No other holes, the screws just pass through either side of the key barrel (which is about 13mm across). The catch latches in the lip of the aluminium frame.
Here's some photos, first the front views of the two halves of the lock - inner part on the left, outer part on the right (the rusty ring on the right photo is where the circular 'brass' ring would normally be seen but which I can't find):
http://i59.photobucket.com/albums/g319/Dalek99999/PA190549.jpg
Next up is rear views of the same two parts:
http://i59.photobucket.com/albums/g319/Dalek99999/PA190550.jpg
On the left photo you can see the rusty remaining two screws (looks like there should be four, but maybe only two were fitted). It looks like the metal plate on the left part should somehow come off to allow the screws to be fitted (so attaching the outer part to the inner plate) and then the inner latch is attached to the inner plate - maybe).
On the right outer lock part a lot of the bit that the screws attach to has rusted away.
Any ideas on a substitute please which will just fit without any more holes needing to be made, etc?
