Hello, I am having a carpet fitted in my large open plan living/dining room on thursday and have some quick questions. I have gone for a decent woven back carpet and the thicker of the foam underlay that was for sale. Also the floor I have is concrete with some thin tiles over most of the room
1. I have some gaps under the skirting of about 0.5 cm in a couple of places. Will this be a problem? and what sort of gap can you get away with? Taking of all the skirting or levelling the floor is not possible now.
2. Along where some gripper rods will go there are some broken bits of old tiles. Now rather than removing all the tiles can I just fill the gaps with cement or laytex self leveling compound?
The reason I ask this is I don't want gaps to get bigger under the skirting where the tiles would be removed. I know I should probably rip all the tiles up but I have been stupid and left things to the last minute (not thinking I would have problems).
3. There a slight incline on the floor in the middle of the room where some walls have been knocked out previously. If I hold my 1 metre spirit level from the highest point to the lowest it shows as being level. Is this just a matter of pouring some self levelling compound out and let it do its job?
You can feel these inclines under the carpet but only because someone previously has put a harsh wedge of cement where the existing walls use to be rather than going for a gradual incline.
Thanks for your time and sorry if I seem abit stupid. I am new to the whole DIY scene and am learning by the mistakes I have made so far. I know the correct answer to all my questions is remove all tiles and level the whole floor but I really can't afford to do this as my room is 10 x 5 metres. Also I only have 2 days.
