I just had new carpet put down throughout my house...dark grey. It was done about a week or so ago and I have noticed quite a few darker fibres in the carpet following vacuuming the place...I thought that it was black polish or some other marks I had made but it is now clear that it is different colour fibres woven into the carpet. Bought it from John Lewis who had an inspector come out to look at another problem (carpet not staying under a door bar) today. He said he hadn't seen so many 'rogue tufts' before...I guess there are around 30-40 in total in various places over a floor area of about 900 sq ft...possibly more as I have moved furniture into place. Some are thick and woven into the carpet...others are finer and can be pulled out with a bit of fiddling. Some can be very clearly seen when you are standing up looking down...others you need to get down closer to the carpet to see.
Their normal procedure is to send someone to try to fix it and if that doesn't help they go to the manufacturer. In this case however, they are going to skip the first step and send a rep from the manufacturer to have a look as the problem looks significant.
My questions are:
1. How common is this problem?
2. Is it fixable or are gaps likely to be left
3. Is it acceptable having spent nearly £4k on the carpets (plus fitting)
4. Should I insist on a replacement carpet throughout?
Thanks all.
My questions are:
Thanks all.
