If you possibly can, you clean out the old one (so it isn't holding lots of rubbish that it can dump into your new system) before you fit the new boiler.
Ideally add the chemical cleaner and circulate it for a week on the old pump, then powerflush, then drain and remove old boiler.
What should I use to clean out a Primatic system ? ........ The way the drawings are going, I'm only going to be retaining about 20 feet of 22mm at the most ........ Should I just change the lot & stop buggering about ?
So I'm ditching, boiler, rads, cylinder, Keeping copper water tank in loft & bout 20' O heating supply tubing.
It was going to be more ....... But we had a bit of a incident & the lounge wall fell over (My fault)
