I need to remove a cast iron bath without damaging tiles, would it be possible to angle grind along back and side edges to release bath from walls, remove bath and grind away fixings.
Thanks guys.
Thanks guys.
what are the walls made of
Thanks "Jackrae" I think your suggestion is better than mine.Exceedingly unlikely and even if you do manage, you will find that the cast iron dust will get everywhere and after you have cleaned it all up there will still be residue lurking about that will then rust once the room starts getting used as a bathroom. Your best bet might be to lower the bath and then slide away from the wall. (The feet may have adjustment screws for levelling) If no adjustment then you might want to consider cutting through the feet to permit lowering.
Is it possible that these baths are not fixed to the walls, relying on their weight alone?Thanks "Jackrae" I think your suggestion is better than mine.Exceedingly unlikely and even if you do manage, you will find that the cast iron dust will get everywhere and after you have cleaned it all up there will still be residue lurking about that will then rust once the room starts getting used as a bathroom. Your best bet might be to lower the bath and then slide away from the wall. (The feet may have adjustment screws for levelling) If no adjustment then you might want to consider cutting through the feet to permit lowering.
Thanks again "Jackrae" You've made my day. Thank youIs it possible that these baths are not fixed to the walls, relying on their weight alone?Thanks "Jackrae" I think your suggestion is better than mine.Exceedingly unlikely and even if you do manage, you will find that the cast iron dust will get everywhere and after you have cleaned it all up there will still be residue lurking about that will then rust once the room starts getting used as a bathroom. Your best bet might be to lower the bath and then slide away from the wall. (The feet may have adjustment screws for levelling) If no adjustment then you might want to consider cutting through the feet to permit lowering.
Yes that's correct
I'd sooner eat a smoked kipper than bash a bath. lolHit it with a large hammer. The bath will shatter and easily be removed
leaving tiles in place or easily corrected.
