Cast iron downpipe
10 Jun 2007
Leeds
I have a cast iron downpipe that has cracked on the lower sections, is it possibe to cut the pipe down with a grinder and then attach plastic downpipe. Is there an adaptor available to connect plastic downpipe to cast iron, i dont really want to replace the whole lot as the top section is in very good condition.
as far as i'm aware you can get a down pipe socket that will fit into cast iron.
but you have to be carefull when cutting it large bits dont fall down inside and cause blockage later.
i learnt that on diynot, see soil pipes
