We have quite a large combi boiler central heating system 15 radiators (13 large cast iron rads) and one of the radiators we've just had refurbished (blasted & powdercoated) has a number of pin hole leaks. The leaks aren't sufficient that its dripping but in operation we're getting tiny black bubbles coming from a couple of the joints.
Whilst fitting the rad and refilling the system I put in 2l of leak sealer as a precautionary measure but I have no idea as to the water volume of the system (but it does take a good while to refil once drained down) so I have no idea if that was enough. The systems been running for a couple of days now but I'm still getting small pinhole bubbling.
Is there anyway I can help the system to target that particular radiator? ie isolate it and top up that rad with sealer directly or is it a case of just adding a bit more sealer to the system till it stops the leaks?
Thanks for any advice
