I have a cast iron soil pipe which runs under the floorboards from the downstairs toilet to the outside manhole, part of the pipe runs under the hall/kitchen for about 6 meters, it goes from the front of the house right the way to the back.
This pipe then runs into a shared sewer which is prone to blocking. Yesterday for example the water was nearly at the top of the manhole. This obviously needs looking at, and I have rung the water company, but this is not the reason for this post.
If the shared sewer is blocked and the water is near the top of the manhole then obviously a large proportion of the cast iron pipe is completely full of water.
But my worry is that one day the pipe will corrode and leak, it's about 60 years old, and then if the shared sewer blocks then the foul water will escape under my hall/kitchen floor.
So my question is, should I invest the money and get this pipe lined? Or would you consider it a waste of money? Also does anyone know how much it would cost to line 6 meters of pipe.
I want to just remove the downstairs loo and block off the pipe but the wife wont have it.
Thanks,
Bob
Thanks,
Bob
