Hi.
Just moved into a house that has a Cata Modus built in oven.
We used it, then turned it off and after probably 10 minutes later, it trips at the fuse box.
I noticed the control panel and front glass was hot, so checked the cooling fan was working. It is, and does its job whilst the Oven is in use. As soon as you turn the oven off, the cooling fan stops instead of over running. We've got round this be turning the temp down after use, and then leaving the door open to get the temp down.
There are limited parts available but i have found a parts list and diagram that shows a 80 degree thermostat connected to the cooling fan. Would it be this causing the problem? There are 2 other thermostats on the oven.
Thanks in advance for any info.
