It doesn't sound like it's the cat causing the problem. The obvious solution you omitted was:big-al said:solution moggy by by
Like us we can't see it either, a picture would be great. I would say your glazier was wrong to say it can't be done over the phone. Nothing is impossible !freebie said:ps glazier told me this over the phone - he hasn't seen the door.
chappers said:he's definitely wrong I cut a catflap into a door in our last house the plastic panels are just expanded foam sandwiched between two sheets of PVC you can always silicone around the cat flap if your worried about any moisture getting in
