Catnic or RSJ size
12 Sep 2008
Hampshire
I am building a new double garage - single brick skin with a 4.6m wide door. There will be an apex style (ie 4 sloping roofs coming to one point) trussed roof above. I have planned 500mm square piers either side of door. I assume I need to allow a minimum of 150mm either end of catnic/rsj. Can someone please advise me if spanning this length can be done by catnic or do I have to get an rsj? In either case will they come with the spec and calculations that they are able to support? Many thanks
Catnic should be fine.
They will do a calculation for you, if you send them a sketch with dims. FOC.
