Caulk - Emulsion Paint and Zinsser
29 Mar 2012
I have put Wurth caulk in the internal corners of walls to hide very small gaps between lining paper. I have to apply emulsion water based paint.
I am not sure which type of Zinser sealer should I use on top of caulk to avoid flashing:
I found three different Zinger sealers:
Blue
Red
Brown
Any help will be appreciated.
I use the red Zinsser BIN.
I don't use it because of flashing, I use it reduce the risk of the emulsion crazing over the surface of the caulk. It dries extremely quickly.
BIN is shellac/alcohol based. Clean brushes in household ammonia. Leave the waste ammonia outside for a day, the ammonia evaporates and you are left with water that has white "dust" in the bottom and can easily be disposed of.
I went to screw fix and they suggested to use blue Zinser sealer.
