Help - I tend to use Polycell Flexible Gap Polyfilla as a caulk, and usually let it dry before over-painting. I have had problems with Matt emulsion cracking - any advice? I read on another thread that painting the caulk with an oil-based undercoat might be the solution, but can I paint matt emulsion over this OK? I was planning to use this method on a vertical corner of 2 rendered and set walls painted in Matt emulsion, where my extenstion meets the original outside wall of my house. Do you think this will work, or should I use a different type of filler in this situation? Many thanks from a real novice!
