Hello,
I have just finished installing laminate flooring in our bathroom. I installed the laminate around the toilet so i currently have a 1cm gap between the toilet and the laminate flooring. The flooring is 12mm thick i was planning on filing the gap with cork expansion strips and then using either caulk or sealant on top to finish it off and to make it waterproof.
I have only just discovered caulk as a product (im new to DIY). Is it as good as sealant? Im wondering which product is best to use in this situation.
Many Thanks,
Glyn
Many Thanks,
Glyn
