Hi, need advice on joining a cavity wall (at right angles) to an existing solid purbeck stone wall. Not sure how to prevent moisture from tracking to internal wall of cavity. Can I grind a vertical slot and insert a DPC or is there another pratical solution. The Purbeck stone is an existing external wall of a property. Infact it is a cavity wall but the purbeck is at least 8" thick and I am not keen to cut a vertical cavity right through. What other ways can I satisfy B. Regs?
Many Thanks
Many Thanks
