Cavity closures - during or after build?
21 Oct 2014
West Midlands
Just doing a bit of online research and have noticed something. Some manufacturers have clips that hold the cavity closure in place that you set into the mortar as you build.
Other times when I see a build there are no cavity closures in place until the last minute once all the bricking has been done. How are these fixed in place?
Is one way better/easier?
Do the cavity closures go all around the opening of a window/door?
The cheapo ones I use are friction fit... you shove them in after the build. They come apart so that you can shave the polystyrene inner down a little if, say, your 100mm cavity has wandered down to 90mm somewhere.
They are a loose fit sometimes and I have to add an extra screw here and there. The last extension I did I also siliconed them in to reduce drafts... a bit OTT but hey ho!
The build-in closers are part of a larger system whereby the window or door being fitted is fixed in the same position as the closer.
I make my own with 100mm Celotex and DPC and then foam them in. I use Celotex wedges to hold them whilst foaming. Mine end up really solid and is the reason I switched from proprietary closers.
Should they be 30 mins fire rated where a upvc window is fitted?
Building control have just made me ammend my plans as the cavity closers were not 30 mins rated.
Hehe, it may be allowed but it's still not great design.
Doesn't the plasterboard clad over the top five you that?
I like the idea of returning the blockwork - makes the wall seem all the more solid and gives something decent to fix into for windows and doors. Just wondering what BC will say seeing as they are so hellbent on minimising thermal bridging....
