An associate of mine is thinking of getting the cavity between the outer brick and inner bricks filled. It is a detached house. I have seen them do it with neighbours. They drill holes into the bricks and squirt some sort of material in.
My question is. Will this material not sit on the ground between the two layers of bricks where there is no DPC?
And if so will this not cause the water to rise up the "material they squirt in" and eventually be abosorbed by the bricks, hence causing dampness, odour and other issues?
