Cavity insulation debate - you'll laugh at one of us...!
25 Jan 2013
Somerset
While ordering our blocks and cavity insulation in the local builders merchant on Saturday morning I get in, what I think is the most ridiculous debate as to what is deemed 'full-fill' cavity wall insulation...
The guy on the counter, who has been selling to the trade for 30 years, was convinced that an insulation product was only 'full-fill' if it had the tongue and groove notch where it joins - and that 100mm fiberglass/rockwool bats were not full-fill!
Is that worrying, or am I misinformed, because my understanding is clear: if the insulation fills the cavity it is 'full-fill - and there is nothing more to it!?
Can you settle this one please?
Cheers
Tom
Full fill just means that the cavity is fully filled, not left with an air gap.
The other type is normally used to save having a backing wall on stone walls.
Both are full fill.
Exactly, so the 'toothing' on the bottom of a 450 x 1200 xtratherm board has nowt to do with the term, and as this would probably be a 50mm sheet it should be installed as a partial fill solution!
Thanks - I knew I was right when he wouldn't bet on it! :)
Tom
