cavity insulation lower level
7 Aug 2010
Manchester
Hi everyone. I am building a small ground floor extension. I understand that the cavity needs to be filed with weak concrete from ground up to 2 courses below DPC. My question is,
at what level does the insulation go in ? Does it sit on top of this concrete or start at DPC ?
many thanks
kevin
IIRC it stops three courses below the dpc.
Fill the cavity from the top of the concrete upwards, even though some is below the dpc.
many thanks Tony, the reason I asked was because of concern regarding insulation getting wet and allowing moisture to bridge the gap. I suppose it would depend on the type of insulation used ?
kevin
