I have recently had a ground extension built using a shared boundary cavity wall. This external wall has now become an internal wall on both properties. The wall extends a metre above my flat roof and it capped with concrete slabs. There appears to be water getting into the top of the internal walls in certain places as the paint has become bubbly. It appears that somehow the cavity insulation is getting wet. Builder appears to be confused about where the water is coming from.
My builder took all the caps off, layed down a DPM and replaced but problem is still present. He has also checked the lead flashing and sealed this but this did not help. Flat roof itself seems to be watertight. I do not understand where the water is coming from? The blockwork is rendered and painted. Could the water be penetrating this? Could the water be coming through the mortar in the end caps?
I've been reading about cavity trays and was wondering if these were installed above the lead flashing would the problem be solved?
Thanks ARH.
Thanks ARH.
