- Joined
- 9 Jan 2022
- Messages
- 3
- Reaction score
- 0
- Country
I have a block built property. It has unfilled cavities. There are vents through the inner wall to outside wall air bricks under the floorboards which work well keeping it all dry. The walls are built on a concrete platform with 500mm between floor joists and concrete. I am considering filling the cavity walls sometime but to prepare I am thinking of fitting a channel through the slot in the inner leaf to butt up against the air brick so that if and when the cavity is filled we do not block the underfloor airflow. Is this likely to cause condensation in the cavities due to the air flow being blocked from spilling in there as it does at the moment?
Thanks.
Thanks.
