Cavity wall clearing
25 Jan 2019
Does anyone have any expericence of cavity wall clearing
I have found the cavity walls have quite a bit of sand in them. The sand bridges the DPC and in some cases goes above 400mm above DPC. Aslo as you go down the wall it turns solid mortar.
I was thinking of trying to get a rotary mutitool in the cavity to break up the mortar.
Also concern about reinstalling the brick. Will the brick take the load, won't the morat shrink a bit and the load taken by surrounding bricks
Stevecc, good evening.
Suggest you try some forward planning? get a snake camera. bore into the cavity, locate areas of issue, work on them ignore the rest of the wall.
Can save some tile and effort.
Ken.
Thanks Ken
I have a snake camera and I can see that where I am going next. So far it seems all the wall.
