Im building a small porch on the rear of my house (2.5×1.5m ish). They will be an L Shaped wall 1m high and 1.5 x 0.9m and the rest pvc. Im looking at doing a cavity wall for this so I see it has, breeze block below ground, brick 4 courses up (for looks) then breeze block up to below window then rendered. using aerated blocks on inner wall above dpc. The cavity 50mm air and 50mm kingspan or is 75mm rockwool wall to wall ok?
