Hi
On one wall in the bedroom there is a regular metal vent (that you can slide on or off with a small grip).
This vent is positioned about 8" off the ground.
The strange thing is, there are 'no outside' vents on this side of the property to provide free flowing air into this vent.
When you get down on your knees near the 'inside vent' there is a distinct musty smell.
About a year ago we had cavity wall insulation done (the cheap 'blown in' fibre type).
Not thinking at the time - this cavity insulation would block any air reaching this bedroom vent.
The bedroom where the vent is, is on an extension that is about 15 years old.
The property is a bungalow, all the floors are concrete BUT on the extension they have fitted that Green Chipboard over the concrete floor, leaving around a 3" gap between the chipboard and solid floor.
I think the floor is called 'floating'
I HAVE 3 QUESTIONS
1) Is it normal for a vent to be fitted like this - i.e. not to have an outside vent to furnish it?
2) Have you ever seen a vent fitted to a cavity wall (other than for a kitchen cooking on gas)?
3) Any thoughts on what I might be able to do, to stop this smell that might get worse, if left.
Many thanks, Stephen
I HAVE 3 QUESTIONS
