I am having a small extension 5x3m built at back of garage. My builder is using earth wool loft insulation to fill the 100mm cavity between brick and block. I don’t think this is a good idea and should be a different type Such as rigid slab dritherm variety. He thinks loft insulation is perfectly fine and that using alternatives is overkill.
Can someone please advise. As walls are virtually at finished height only option now is blown in
I’m really at a loss
