Hi Guys hope you are all well
I own a 3 bed 1930 semi which I though was solid wall. i have just drilled a 4" core through the wall for a boiler flue and have discovered a cavity approx 2 -2 1/2" wide result I think
Anyway before we moved in we had an injected DPC and I installed a vertical damp as some numpty had breached the existing with a driveway and patio around the outside
My question is should I get this done as I have had a damp problem would fibre wall insulation make the problem worse ?
The DPC was injected on the internal walls only and not all of the house
Many thanks in advance
