Hi all,
I've a single storey rear extension coming up. I advised the builder to keep a 75mm gap for cavity wall (to save space for the room). We are at damp course level now.
The buildings inspector has come around and said, "We like to see 100mm cavity, but as you have gone for 75mm, I would advise to use dritherm32 cavity wall insulation along with insulated plasterboards using dot and dab method".
Not only this is super expensive as I am finding out, the problem is that the dritherm32 is "slab" type of board that is quite rigid. The brickey is asking for a roll that is not rigid so its easier for him to insert between the wires holding the 2 walls as well as it helps by not displacing the blocks due to non-rigid nature of roll.
Can someone please advise if I can get a decently priced non-rigid/ semi-rigid type of insulation that comes like a roll and insulates well?
Many thanks in advance..
