gasbanni, good evening.
The shall I call it, General principle of introducing insulation into the cavity is a very attractive concept, primarily a warmer home.
Down side is as we all know cavity bridging on an enormous scale, far greater than a mortar blockage in a cavity or even a half brick occasioning the bridging.
I have seen many, many dozens of such cases of cavity insulation occasioning horrendous damage both internally and externally.
If you have the time and more especially the inclination, you will find research that clearly states that Cavity Wall insulation is NOT advised in almost all areas of the UK??? the exposure to wind driven rain Etc, there are graphs and maps that indicate areas where such installation is simply not advised, and I am not typing about a property on top of Ben Nevis???
Several years ago there were many, many job adverts for so called "Cavity Wall Surveyors??" the outstanding part of the adverts made it abundantly clear that there were "No Previous Experience" was required???
There are several on-site checks that the cavity wall surveyor should check for by drilling into the cavity from the external these checks are supposed to include, the width of the cavity?, has the cavity been filled historically?, using a bore Scope the surveyor has to check for cavity blockages, but given the last phrase in the foregoing paragraph I for one do not think the Sheriffs won over the plethora of Cowboys.
Early versions of Cavity Fill, such as blown fiber were a complete disaster in places.
Historically I do well recall the use by bricklayers of Cavity boards, they worked, but is one was left in place the internal damage was nasty, but nowhere as bad as cavity fill.
Any remedies??
Removal and drying of the walls is fairly well known, but who pays??
Most / all such Installations were [so called] backed up by an insurance [of sorts]
Big trick is to find out who Underwrote the original Insurance Policy which covered the Installation, if you can locate the Underwriter then once they accept Liability they will pick up the tab for repair.
A complete can of worms??
Today's massive innovation will give years of future investigations as to the remedy to the original innovation??
Ken
