It's mostly likely the damp is bridging across the wall tieraittser said:Have been informed from friends that it causes dampness due to lack of air in cavity. Is this true?
I don't think so, only a small number of properties, my theory is how many houses are not insulated correctly, I have replaced many windows in my time and was shocked I couldn't see any insulation in the cavity in some of them when windows are taken out. The other problem I'm seeing is the bottom of the cavity is full of mortar dropping just over the dpc level and the foam can only rest on top of it so damp could bridged across to the inner wall, doesn't happen today as they use insualtion slabs^woody^ said:Does this mean that every house with cavity insulation gets damp?
