Cavity walls
1 Mar 2011
Telford
Hi
Should the tops of cavity walls be sealed or open?
In my extended bungalow, I can look down into the cavities from inside the eaves - should this opening be covered up?
OK so they can be closed or open, doesn't matter?
Mine are open, I can look right down inside the cavity and even see the polystyrene insulation board!
Modern cavities are usually closed, unless a full fill is used, as heat is lost through an open cavity.
